lift kit or other ideas???
have a 2002 chevy hd and want to make the suspension smoother and softer
dont really need the HD part anymore
any idea?
want a much more plush ride on the street and on the beach over the small stutter bumps
right now the ass end bounces all over the place as if on pogo sticks
Traction bars may help you with the wheel hop on the beach...I think they're called traction bars....I think fabtech makes some for the 2500HD. You could try putting a few bags of quickcrete back there too :thumbs:
Better shocks, Velvet ride shackles and traction bars. If you had a 1500, it would do the same thing over the wash baord bumps on the beach.
well thats just it
I had a 01 gmc z71 excab and it was a dream on the beach but I needed the crewcab and the extra towing capacity so hd it was. Now I dont need the HD part and want the more plush ride.
At this point money isnt really an issue but I dont want to change trucks, just want to make this one better
is there a lift kit that might be smoother
Jeremy, I don't think that a lift kit is your answer as most come with blocks to lift the rear. I would look into a set of velvet ride shackles or a set of Deaver springs. If you still have the factory shocks on it get rid of them quick, go with a set of Bilstein's, Rancho RSX's or Edelbrocks wIAS, you will be amazed at the difference they make. If what you are experiencing is hop when under acceleration then a set of traction bars will help solve that, or a set of Roadmaster Active Suspension springs. Just what I come up with off hand. :D
I think I will give the edelbrocks a try...or ???
maybe I will start a poll
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
