Dealer is kind of at a lose trying to figure out a clunking noise that seems to be in the area of the TC and front drive shaft. The noise is like a rotating clunk so they figure its in the drive line somewhere. The have had it on a rack both for a visual inspection and getting all 4 wheels spinning with no luck duplicating the sound. The did try a TSB on re-alaigning the TC but that did not help.
The noise happens only when letting off the gas and is louder on the freeway. Truck has 1076 miles.
Is this normal for the front drive shaft at the TC?
Every gear or only from 2>1?
It's unfortunately "normal" for HDs to clunk from second to first due to crap trans/throttle mapping in the tune.
However, I have a buddy that had a clunk on his 24 and also a surge when placing in reverse, forward...etc and the dealer is telling him its a trans module and that "3 other trucks with the same thing" came in behind his which I highly doubt since we haven't seen this issue online en masse.
  • 3 weeks later...
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 929 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
