Installed a 12v socket in my 2024 GMC Sierra GMC 2500HD AT4 today. Goal was to connect the 12v socket to the Aux battery. I've been trying to get a 16 gauge wire through the bottom of the firewall feedthrough on the drivers side. I tried a stiff wire, X-Acto knife, long skinny screw driver, etc. I was able to make a small hole and get a piece of 12 gauge house wire through but was a pain getting the other wire to come through the nipple on the inside.
I got a Diablo 1/4" spade bit at Ace and was able to drill a hole big enough to get a 16 gauge wire through by bending the edge over the end of the long skinny screw driver and pushing it through the hole from the engine side. I taped that wire to one of the 12AWG wires and used a drop of oil spread on the tape and pulled it through the firewall. Taped the other 12 AWG wire to the first one and pulled it through.
I used Wirefy connectors with built in heat shrink and an Ancor crimper, got both from Amazon. 12v socket is a Bulldog Winch 12v 20A part number 20286. Bulldog Winch wanted a lot for shipping and got it from etrailer. It's rated for 20A, fused it at the Aux battery with a 15A fuse. Connected the negative wire to the ground bolt for the aux battery on the top of the fender. It comes with 3 different mounting options. I used 12 AWG red and black wiring from a local West Marine along with 3/8" split loom from West Marine. Split loom claims it is self-extinguishing. Secured the 12v socket with Scotch Extremely Strong Fasteners. Not sure how it will work but will probably have to hold on to the socket when connecting anything to it.
See next post for more pics.
Edited by rjgvt
First pic is wires inside the cab from the feedthrough.
Second pic, socket is mounted to the lower dash to the left of the console with the Scotch fastener.
Third pic: I moved the excess wiring/loom away from heat duct output. I tucked the excess in the side panel. I might move it more to the right of the heater duct.
Fourth pic: Wiring in loom from dash feedthrough.
Fifth pic: Wire loom from feedthrough to aux battery.
More pics. I ty-wrapped the wiring/wireloom to the other wiring in the engine compartment away from any liquid carrying hoses.
Last pic is where I mounted it before wiring it.
Just wanted to add that to make it easier to work on the feedthrough from the engine side, I laid a moving blanket across the front of the truck and engine. I used a ladder next to the front of the truck with the blanket protecting the truck. I initially tried working next to the drivers side on a HF step stool and was not able to see what I was doing.
Rerouted the wire loom under the dash to behind the heater duct and tucked the excess in the console panel. Also some finished pics.
Plan is to use the USB socket thing for plugging in my Garmin Inreach Satellite Communicator. My last truck had two 12v sockets, one was always on and used it for charging the Garmin every day or two. I could charge it in camp but would probably forget it so I leave it in the truck during hunting season.
Edited by rjgvt
    250.3k
    DjmFingerstylePlayer
  • Who's Online   3 Members, 0 Anonymous, 607 Guests (See full list)
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
