Hey All,
I'm having issues getting the A/C working correctly on my wifes truck. She has an extended cab 2011 Silverado 1500 LT, 5.3L with driver and passenger side controls.
The long and short of it is I have replaced every component of the system except for the evaporator - which was flushed out and clear of any obstructions. The low side fluctuates between 50 to 80 PSI, with the high side ranging from 80 to 130 PSI. I also noticed the electric fans were not consistently on with the A/C - yet they do function.
I'm beginning to think that maybe there is a common electrical issue that I am unaware of.... any advice/help would be appreciated.
Thank you....
High side pressures are low. Check the orifice tube for debris and correct size
And the low side is high.... which normally seems to be indicative of a faulty compressor - which was just replaced.
Orifice tube is clean, and appears to be the correct size.
    1981dustin
    1981dustin
  • Who's Online   2 Members, 0 Anonymous, 1,534 Guests (See full list)
