Let me preface this with that of all the things I've done myself to my trucks over the years,  I've never done my own brake job, so I'm not intimately familiar with brakes. With that said, a few months ago, I got the GM Performance brake system put on at the dealer and noticed pretty quickly that there seemed to be more resistance to a free spinning tire right out of the gate.
It's not my daily and park in a garage, so when I go to drive it, will start it up, put it into neutral and it will roll slowly out of the garage onto the driveway and by the time it does, it has usually calmed down to it's normal idle RPM. However since getting that package installed, It won't roll out and only moves a few feet. So over the weekend I pulled off one of the front tires and was inspecting the brake setup, among other things, and noticed that I could not very easily spin the wheel. It takes a little bit of muscle to rotate it and it's not free spinning like the OEM's were. I could tell that the pad was pressed up against the rotor more than I would think it should be, creating the resistance. However I don't have any experience in this area.
Are big brake kits supposed to be like that?
No, they are NOT they should spin as easily as the OEM's I have done many brake jobs myself over the years, something is amiss here.
Did you get Calipers, rotors and pads all as a set, was the system bled properly? does it pull to one side while driving,..... and or while braking?
The pad should not be touching the rotor at all unless the pedal is being pushed down, take the wheel off with it up on a jack and safety stand and check out the pad/ rotor contact itself or go to a brake shop that has a great reputation and ask them to check it out.
OR you could try showing the dealer the issue, most dealers seem to suck IMO though.
Specialty shops seem to do better.
On another subject did you post up anything on the whipple anywhere, I was just looking at that option as I am near the end of warranty.
Yeah, was the package from GM accessories site and installed by a local dealer. I'll pull the passenger side off tomorrow and check it as well. Here's a short video I did this evening of my trying to rotate it.
There are no other issues aside from that..no pulling or anything
On the Whipple. yeah I posted something back in March..here's the link. I'll be posting more there relatively soon. I've done a fair amount since then.
Edited by SierraStorm21
    Chris80s
    Chris80s
  • Who's Online   5 Members, 1 Anonymous, 827 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
