I'm not very mechanically inclined. I have an oil leak when I took my truck to the mechanic he said they would replace the transmission lines. I asked him to hold off for now because I didn't have the extra cash. Is there any product I can add to my oil to hopefully help the oil leak? Thanks in advance.
Help the leak how?  You can add fluorescent dye to find the origin of the leak, but there's nothing in a bottle you can add to stop a leak.  And transmissions are very sensitive to anything but transmission fluid in there.
All you can do is fix the leak, so if your transmission lines are leaking, replace them ASAP so you don't burn your transmission up.  $400 for some new lines is a LOT better and cheaper than $6000 for a new transmission.
Edited by newdude
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
