Tire questions
Hey guys,
I want to upgrade to silverado 17" wheels. Now here is the deal. I want to put a set of either BFG all terrain's or mud terrain's. Now what size would be like what I have on my truck now? I have 285/75/16's. Can I get those in 17's and would they fit? I need some suggestions. :shakehead:
Just curious, what you are going to do with the wheels/tires that are on there?
I'm kind of in the market for a decent set of used tars.
Would most likely sell them. Why you interested?? :nono: I looked up and found a 275/70/17, would that fit or even look as good as what I have? :shakehead:
From my math, you can get 285/70/17 and they will be just about the same size. Will be about 1/10th of an inch shorter, and the same width.
But I'm no tire fitment guru. Double check with somebody else :shakehead:
**Edit**
I'm in the market for some 285's for the 92...But I don't need wheels. I have three sets already. Shipping would negate any sort of savings you could probably give me anyways. Nice to dream though. :nono:
**Edit**
Yeah, I thought you needed a set of wheels. If you change your mind, let me know. :D
Can anyone verify that 285/70/17's will look okay?
Okay, I am pretty sure its gonna look fine. But, now I am concerned with it scrubbing? Maybe my math is off, but I think it will. My torsion bars are jacked up. So what do ya'll think? :shakehead:
Well, I have thought about it. And I am just gonna keep the 16's. I like the look better and tires for the 17's are fuggin' outrageous. :shakehead:
  • 6 months later...
Tell me about it. I just ordered a set of 285/70/17 GY MT/R for my 04 GMC Z71. Will let you know how they do on stock susp when I go play this weekend (assuming they come in before then)
Got my MTRs installed today. They're 285/70/17 on stock truck and they fit just fine with enough room in the front to accomodate suspension travel and turning. They look like they might rub a little under hard turning with steep suspension angle, but that's about it.. They make the truck look a lot better than the stock Dueler ATs that came with it.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
