Hey! Planning to swap to the chrome bumper trim piece from the Denalis on my SLT and was curious if the bumper had to be removed entirely to do this, or if anyone had any guides on how to remove solely this trim piece. Plenty of these offered on ebay but haven't found any info on how to install them... Thanks in advance!
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
