I just installed a RAS on my 25 RST Z71 and it lefted the rear by about an inch, didn't mind the look in stock form but now with the ass sticking up more and it's kind of bothering me.
I know my best option is to go with some Bilstien B8 5100 which I will probably do in the future. I'd hate to toss out perfectly good struts with under 1k miles on them.
For simplicity, I ordered the 2" leveling spacers that goes on the bottom of the struts. My 19" have the 2" upper spacer which was fine, I've just never used these lower ones. Anyone have them with positive results? I assume this would void my factory warranty on the struts and maybe a few other component that attaches to it.
To be honest, I don't like the front level as it takes away my visibility a little with the hood pointed up.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
