Start/stop eliminator only, doesn't disable AFM. I have had it for about 5 years on 2 trucks, a 2019 Denali and 2021 AT4 both with the 6.2l and worked great. Trading in the AT4 so don't need anymore.
$60/shipped in the US
Edited by wurgs
  • wurgs changed the title to sold
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
