I have some parts left over that are in usable condition from a set of running boards I built combining 2 sets i purchased.  Parts include end caps, endcap with switch, idler arm with wiring harness both sides, and PS motor and arm, DS motor arm and gearbox needs a new motor, controller box that goes on the DS assembly.  Let me know what you are interested in and we can work out a price.  I'm in the Cincinnati area for local pick up or parts can be shipped if you want to pick up the tab for that.
  • 1 month later...
I should, let me look.   Before replacing your motor though I would make sure the pivot points aren't getting stuck at the running board pivots as that will just burn up a replacement motor.  Before I put mine on I took them apart and freed them up with solvent then antiseize.  Your motor might be fine if it's just trying to move frozen pivot points.  I'll look to see where I put the motor though and let you know tomorrow.
i have the PS motor, let me know if you decide you need it - like I said I would make sure things move smoothly first or you will burn up any new motor you put on it and yours may still be fine.
  • 2 months later...
Sorry, never got a notification. I am going to check pivot points this week. Thanks for the tip.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   0 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
