vucelick Posted August 10, 2025 Posted August 10, 2025 Need a second set of tpms sensors for my winter wheels, any good sources online for the OEM ones?
newdude Posted August 10, 2025 Posted August 10, 2025 52 minutes ago, vucelick said: Need a second set of tpms sensors for my winter wheels, any good sources online for the OEM ones? Shop Chevrolet Accessories | Official Chevrolet Store Build your vehicle in there and go to the wheels section for it. They are $40 each from the accessories catalog and you can pick them up right at the dealer or pay for shipping.
vucelick Posted August 10, 2025 Author Posted August 10, 2025 I was hoping to find the oem ones discounted like partsdirect or something, looks like the dually sensors are $85 ea
newdude Posted August 15, 2025 Posted August 15, 2025 On 8/10/2025 at 7:05 PM, vucelick said: I was hoping to find the oem ones discounted like partsdirect or something, looks like the dually sensors are $85 ea Not the dually ones. Look for the ones that are $40 each. They are the OE sensor.
newdude Posted August 15, 2025 Posted August 15, 2025 (edited) On 8/10/2025 at 7:05 PM, vucelick said: I was hoping to find the oem ones discounted like partsdirect or something, looks like the dually sensors are $85 ea Here. 2024 and up HD single rear wheel use THIS - Chevrolet Tire Pressure Monitor Sensor (XL8 - 433 MHz) | 86530815 | Chevrolet Accessories 2020-2023 HD single rear wheel use THIS - Accessories Edited August 15, 2025 by newdude
vucelick Posted August 15, 2025 Author Posted August 15, 2025 (edited) I have a 2025 dual rear wheel truck. The set of wheels i purchased are from a 2017 chevy dually. I am not sure the wheels are compatible with tpms sensors. I will take a look when the wheels arrive today. Edited August 15, 2025 by vucelick
rjgvt Posted August 17, 2025 Posted August 17, 2025 After reading different TPMS posts here with different part numbers, I went to the parts counter at my dealer. Gave him the VIN for my truck and he gave a part number for the TPMS sensors that matched the same number that my Autel gave me. Ordered 4 from the dealer and had the tire shop that I use install them in my winter wheels/tires. The part number that I have is different from any of the links posted above.
newdude Posted August 17, 2025 Posted August 17, 2025 On 8/15/2025 at 5:29 PM, vucelick said: I have a 2025 dual rear wheel truck. The set of wheels i purchased are from a 2017 chevy dually. I am not sure the wheels are compatible with tpms sensors. I will take a look when the wheels arrive today. DRW the only option will likely be OEM sensors only then. The old sensors won't work, you need 2024 HD dually and newer sensors.
newdude Posted August 17, 2025 Posted August 17, 2025 1 hour ago, rjgvt said: After reading different TPMS posts here with different part numbers, I went to the parts counter at my dealer. Gave him the VIN for my truck and he gave a part number for the TPMS sensors that matched the same number that my Autel gave me. Ordered 4 from the dealer and had the tire shop that I use install them in my winter wheels/tires. The part number that I have is different from any of the links posted above. The p/n you have is for individual sensors. The ones I linked are individual but the p/n is for a pack of 16 of the OE p/n. We can order them individually from our GM ADI (accessories distributor) and it saves customers some $$$ over the OE individual p/n.
rjgvt Posted August 17, 2025 Posted August 17, 2025 57 minutes ago, newdude said: The p/n you have is for individual sensors. The ones I linked are individual but the p/n is for a pack of 16 of the OE p/n. We can order them individually from our GM ADI (accessories distributor) and it saves customers some $$$ over the OE individual p/n. Thanks, have not seen it explained like that when this topic comes up. I wanted to make sure I got the right sensors months before I was putting my winter wheels/tires on. The sensors I got from the dealer were the least expensive items compared to the price of Hakkapeliitta LT3 studded snow tires and another set of GM wheels.
vucelick Posted August 18, 2025 Author Posted August 18, 2025 23 hours ago, newdude said: DRW the only option will likely be OEM sensors only then. The old sensors won't work, you need 2024 HD dually and newer sensors. I figured that was the case, will the correct, new sensors physically fit the older style wheel? I assume so, but dont want to make a costly mistake.
vucelick Posted August 18, 2025 Author Posted August 18, 2025 (edited) On 8/17/2025 at 12:59 PM, rjgvt said: Thanks, have not seen it explained like that when this topic comes up. I wanted to make sure I got the right sensors months before I was putting my winter wheels/tires on. The sensors I got from the dealer were the least expensive items compared to the price of Hakkapeliitta LT3 studded snow tires and another set of GM wheels. Dually? Or single rear wheel? I am trying to determine if the inner dual rear wheel sensor is the same as the rest. It looks like it has a longer stem. Edited August 18, 2025 by vucelick
rjgvt Posted August 18, 2025 Posted August 18, 2025 45 minutes ago, vucelick said: Dually? Or single rear wheel? I am trying to determine if the inner dual rear wheel sensor is the same as the rest. It looks like it has a longer stem. Mine is a 2500 AT4 SRW gasser. I don’t think that 2500HD’s are available in a dually.
newdude Posted August 18, 2025 Posted August 18, 2025 (edited) 18 hours ago, vucelick said: I figured that was the case, will the correct, new sensors physically fit the older style wheel? I assume so, but dont want to make a costly mistake. They should as they use the standard .453" valve stem holes and not .625" holes like trailer wheels will. If you have 6 steel wheels uses 6 of p/n 13554170 and 6 of 13581557 nut to secure the sensors as they are clamp in sensors and not rubber snap in stem style. If you got the aluminum wheels, needs 2 of 84890237 for the fronts, and 4 of 13554170 for the rears. You also need 2 of 84312389 nut and 4 of 13581557 nut to secure the sensors as they are clamp in sensors and not rubber snap in stem style. Valve stem extensions for the inners are p/n 9417745. Edited August 19, 2025 by newdude
vucelick Posted August 18, 2025 Author Posted August 18, 2025 Mine is the LTZ, it has the 18" aluminum wheels, but the rear inners are steel.
