newdude Posted August 19, 2025 Posted August 19, 2025 (edited) 15 hours ago, vucelick said: Mine is the LTZ, it has the 18" aluminum wheels, but the rear inners are steel. Correct. The stuff I posted for the aluminum wheels would apply to the aluminum 17" and 18". So whatever wheel set you got for your winters be it the 6 matching steels or the aluminums (which have location specific mounting), the info is all there. You would order according to whatever OEM wheels you have bought for winter use. I also added the # for the duals valve stem extensions as I forgot that. Edited August 19, 2025 by newdude
vucelick Posted August 19, 2025 Author Posted August 19, 2025 Excellent, so a point of clarification, the wheels i purchased are 17" wheels from a 2017 truck. I assume that the sensors you specified as compatible with my 2025 truck will physically fit and attach to the older wheels?
newdude Posted August 19, 2025 Posted August 19, 2025 16 minutes ago, vucelick said: Excellent, so a point of clarification, the wheels i purchased are 17" wheels from a 2017 truck. I assume that the sensors you specified as compatible with my 2025 truck will physically fit and attach to the older wheels? Correct.
Register a new accountSign in
