On 8/10/2025 at 7:05 PM, vucelick said:
I was hoping to find the oem ones discounted like partsdirect or something, looks like the dually sensors are $85 ea
Not the dually ones.  Look for the ones that are $40 each.  They are the OE sensor.
Here.  2024 and up HD single rear wheel use THIS - Chevrolet Tire Pressure Monitor Sensor (XL8 - 433 MHz) | 86530815 | Chevrolet Accessories
2020-2023 HD single rear wheel use THIS - Accessories
Edited by newdude
I have a 2025 dual rear wheel truck.  The set of wheels i purchased are from a 2017 chevy dually.  I am not sure the wheels  are compatible with tpms sensors.  I will take a look when the wheels arrive today.
Edited by vucelick
After reading different TPMS posts here with different part numbers, I went to the parts counter at my dealer. Gave him the VIN for my truck and he gave a part number for the TPMS sensors that matched the same number that my Autel gave me. Ordered 4 from the dealer and had the tire shop that I use install them in my winter wheels/tires. The part number that I have is different from any of the links posted above.
DRW the only option will likely be OEM sensors only then.  The old sensors won't work, you need 2024 HD dually and newer sensors.
The p/n you have is for individual sensors.  The ones I linked are individual but the p/n is for a pack of 16 of the OE p/n.  We can order them individually from our GM ADI (accessories distributor) and it saves customers some $$$ over the OE individual p/n.
Thanks, have not seen it explained like that when this topic comes up. I wanted to make sure I got the right sensors months before I was putting my winter wheels/tires on. The sensors I got from the dealer were the least expensive items compared  to the price of Hakkapeliitta LT3 studded snow tires and another set of GM wheels.
I figured that was the case, will the correct, new sensors physically fit the older style wheel?  I assume so, but dont want to make a costly mistake.
Dually? Or single rear wheel?  I am trying to determine if the inner dual rear wheel sensor is the same as the rest.  It looks like it has a longer stem.
Edited by vucelick
Mine is a 2500 AT4 SRW gasser. I don’t think that 2500HD’s are available in a dually.
They should as they use the standard .453" valve stem holes and not .625" holes like trailer wheels will.
If you have 6 steel wheels uses 6 of p/n 13554170 and 6 of 13581557 nut to secure the sensors as they are clamp in sensors and not rubber snap in stem style.
If you got the aluminum wheels, needs 2 of 84890237 for the fronts, and 4 of 13554170 for the rears.  You also need 2 of 84312389 nut and 4 of 13581557 nut to secure the sensors as they are clamp in sensors and not rubber snap in stem style.
Valve stem extensions for the inners are p/n 9417745.
Edited by newdude
    scotthvac.net
    scotthvac.net
  • Who's Online   2 Members, 0 Anonymous, 390 Guests (See full list)
