On my 06 2500HD I cleaned the vents in dash and turned a couple a light color. Has anyone found a plastic paint that matches the gray color ? Thank you
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
