18" AE 102 wheels/35" Nitto TerraGrapplers
It's time to upgrade my HD's wheels and tires for this year so the current package is for sale. That is a set of 18x10 American Eagle 102 wheels with 325/65/18 Nitto TerraGrappler tires (35s). They have only been on the truck for about 4500 miles so everything is in very good condition. Centercaps and lugs will be included. I'm looking for $1075. + shipping (firm). This package retails for about $1700.
Tom
2002 8.1 Silverado HD - Comp Cam, TOG headers, Volant induction, Direct Hits ignition, 8" lift 18" wheels/tires + more
2002 8.1 Suburban -Intercooled Whipple supercharger, TOG headers, Volant induction, 22" wheels/tires + more - 407hp/558 ft-lb torque at the rear wheels.
www.tbyrnemotorsports.com
tom....what type of finish on the rims? Clear coat or?
also do you know what the lowest recomended psi on that set up is?
Um... give me a few minutes... I'm trying to watch the girl walk down the street :cheers:
The American Eagle wheels have a polished finish. They are very shiny when clean. I don't see a lowest psi rating but I can tell you that they have a D load range.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
