Leveling a IFS Burb ???
I hate the stance of the late model Suburbans!
I have an 02 Z71 Burb and it like all of them sits front end down and the rear a little higher than the front.
it there a way to level this out and raise the front about an inch or so??
I know Ford has leveling kits for their F-250s.
Please help!
  • 2 months later...
Hey Alex,
There is a way to do it and it involves a little more than just cranking up the torsion bars. Simplyg adjusting the bolts will cause the torsion bar keys (do a search on that) to bottom out before any signifigant height is gained. The torsion bar keys can be changed to a differently indexed hex which will intern give you a different range of adjustability.
Check out this link
http://www.hill4wheeldrive.com/cgi-bin/pro...item=5479418692
I had them in my last k2500 pick up and it only slightly changed the ride performance and I beleive it was due to the lower control arm bumpers having a gap between the lower control arm and the bumper vs stock which is smashed up against the bumper....In other words when you hit a bump you could feel it hitting the bumper.
I just bought a k2500 suburban and need to find out if changing the front suspension height will adversly affect the front shocks but I know I can extend the arm for the height sensors or the conntecting rod to fool it....Just not sure its necessary.
The look and cost are worth the expense...I cant stand looking at my truck from the side on level ground at the moment!
Doug
The Hill leveling kit is the same thing as replacing your torsion bar keys with Ford keys. In fact it is thought that the Hill keys ARE ford keys with the ford part numbers ground off. Ford keys will run you about $50 shipped to your door.
...... Simply adjusting the bolts will cause the torsion bar keys (do a search on that) to bottom out before any signifigant height is gained. The torsion bar keys can be changed to a differently indexed hex which will intern give you a different range of adjustability.
Mine aren't bottomed out, and I gained more than an inch (all that is needed).
As for the "re-indexed" keys...They are the torsion bar keys off of a 1/2 ton Ford...Just like woyster_00z71 said. And picking them up at a Ford dealer will cost significantly less than a "leveling kit".
Now thats some good info!
Anyone have part #'s that'll fit my k2500 suburban?
Are there any concerns with the weight carrying ability as I have an 8.1 riding around in the front?
Anyone now how autoride will be affected?
Doug
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 675 Guests (See full list)
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
