I'm in the process of getting my new '26 AT4 for work. I currently have a standard over rail took box, however, I'm considering the DECKED Drawer System. For members who've had these systems in their trucks, I'd like to hear your thoughts & experiences with them.
  • I've read where they aren't as weatherproof as claimed. What are your experiences? Dry after car washes?
  • What do you like the system?
  • What do you not like about the system?
  • Would you buy one again? If not, why?
  • Have you found any modifications or non-DECKED items that work well in them?
Thank you.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
