Hello All. Have a 2015 Silverado which has the black cover on the rear window trim. The plastic has disinegrated from the sun. Can the black cover be purchased separately or do I need to get the entire piece (with 4 clamps). P/Ns would also be appreciated. Thank you.
From what I can tell, the 23227178 P/N is for the chrome version of the trim. Anyone know the P/N of the black version? Thank you.
Go to that link again & scroll the picture. The black on is on the same item. Just make sure it's for your type of door. Crew cab or double door.
Bought a P/N 23227172 and it a match for my old piece. Thanks all.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,609 Guests (See full list)
    • I have 2 choices.
