The headlight bezel is coming off my truck.  I drove across the country and noticed it then.  How do I take this off without breaking it to replace the double-sided tape I heard about?  Is there a part number for the correct double-sided tape or are there possibly clips?
Thank you.
Edited by sddoublee
typo
My go to double sided adhesive is 3M emblem tape. It comes in various widths. The key to making it work best is to clean off both sides thoroughly and completely. This can sometimes be a bit tedious but is very important. I will often use isopropyl alcohol to do this on all involved surfaces after using an adhesive remover. 3M also has an excellent adhesive remover but is a bit pricey. But it works great.
Edited by mikeyk101
