I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 586 Guests (See full list)
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
