Hey everyone, I recently had an issue with my 07 2500HD GMT900.
My DRL’s stay on at all times. Right front turn and right mirror turn signal indicator stay on solid at all times. By “at all times” I mean the only way to make them go off is disconnecting the battery.
I tore the headlight assemblies out, tried disconnecting the harnesses to eliminate bad wiring at the harness, I unplugged the headlight switch, no change and the mirror turn signal still stayed on.
My first thoughts were : Bad bulb and/or socket somewhere, under hood fuse panel bad, bcm bad, tail light or trailer wiring problem, or some random short to power in the harness.  Possibly a bad ground but unlikely.
I had a big clue in the fuse panel, it had a burnt smell. I started pulling every fuse that had to do with DRL or right turn/park lamp. Nothing made the right directional turn off but pulling the DRL2 fuse made the DRL’s go out.
After studying wiring diagrams, I found that both problems had that fuse panel in common, the bcm also controls both problems but knowing the fuse panel had a burnt smell I removed and disassembled the fuse panel and found a little corrosion on the printed circuit board.
I ordered a new fuse panel from Amazon for like $260. When it arrived I installed it, and put everything back together, the problem was fixed. I figured the fuse panel needed to be replaced anyway so that was a logical place to start.
Hopefully this story helps someone in the future.
Regretfully I didn’t scan for codes before I did everything.IMG_4229.thumb.jpeg.be86ec41ceb8af7ed868fc1ba4547513.jpegIMG_4232.thumb.jpeg.247434c9eb5c0841fbd320d7363b4d51.jpegIMG_4230.thumb.jpeg.85f2dc4c2b5e6603c70549839ed09ab5.jpegIMG_4226.thumb.jpeg.a930e0a0131920a2f842d3b8ada251db.jpeg
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
