WTB 01-03 NBS Denali rear bumper
looking to upgrade my paint job... I'm looking for a decently priced new or used denali or escalade rear bumper (complete) I would also consider a paintable z71 bumper (in which case I only need the bumper itself)
Not that you'd want to but I'd even trade the old one towards the new one.
I have a 2003 GMC yukon (about six months old)
Thanks :cheers:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
