Big Screen TV Gurus'
Shaners
My Toshiba 50HX70 has apearantly taken a hit (physical). The kids, wife and dog aren't admitting to it (I Think they're scared).
Anyhow, it appears my convergence is way out of wack in the Blue Spectrum. The positions 7, 8 and 9 are the worst and I can't move them back in far enough with the remote.
Is this realignment that I'm going to need something I can do myself? Or am I better off paying what will most likely be several hundred bucks and have a technician come to my house? Also will it hurt the TV using it like this until I get it fixed?
I looked inside the TV and didn't notice any obviouse way to adjust the Blue projector.
I'm sure there is a combination of buttons to press on the remote to go into a diagnostic mode, but I haven't found enough info yet...
thanks for the link, and I'll keep diggin'!!!
I'd just pay for a professional. Not only will they realign the color guns physically, but they'll clean them and the mirror which will wake that tv up a little. You can also have them cailbrate it to get the very best picture out of your tv.
Shaners, that's a 50" 4:3 HDTV isn't it?
You might try Keohi.com for some good advice:
http://www.keohi.com/keohihdtv/brandspecif...shiba_tips.html
Have you ever done a 56pt convergence? This sounds like what you need to do to correct your geometry. Get your green grid lined up as best you can and then converge the red and blue to it.
I have the 50H72 which is basically the same tv jus' a little newer. I have converged it dozens of times so let me know if you need any help.
Good luck
It sounds as though your actual gun got moved. Convergence is simply a fine tuning feature that allows "us" to dial it in. I would highly recommend having a professional come in and do this for you. Now, I would be there with him and have him show you what all he is doing so if it ever happens again you will have some knowledge and be able to do it yourself. While you are paying them you might as well have it calibrated, too. Yeah, it'll cost a few hundred, but, believe me it's well worth it. I have included a link to where you can find someone near you that can perform all of this for you.
http://www.imagingscience.com/isf-trained.cfm
stebob, There was no-one from imaging science that was really local to me... the closest is about an hour from here. I called the local TV repair service and they claim to be able to work on bigscreen TV's. They are calling back tomorrow because the Technician was out for the day. I want to talk to the guy before I commit to him... because I can screw up my TV just as easily as he can!!! LOL!!!
melbertbloosfan, thanks for link and there was alot of info on that site about Toshiba TV's. I'm not sure about the 56pt convergence. I can do a 9 pt from the onscreen menu, but the bottom 7-8-9 are badly bowed. There isn't enough adjustment to even bring them close. The number 8 looks like this...
(blue) +
(white) +
2 plus marks floating over eachother when they should be sitting directlynon top of eachother (Making just 1 plus mark instead of two). I think the blue gun has somehow been physically moved a fairly large amount, and will need to be mechanically adjusted back in spec.
I'm not a happy camper right now... :cool:
This site is pretty good, enough tho it is Panasonic based, might help you.
http://www.panny.tv/
Sounds like you may have to go inside, (service menu) carefull! Make sure you wright your settings down prior to doing anything and save only when good I have read a lot of horror stories from people playing around inside, not knowing a bunch. End result an expensive rug flatner or $500 to convert back to a RPT.
:cool:
John
Here is what I see across the bottom of the screen:
Let's assume there is a line of (what used to be) "white words across the bottom of the screen.
Now-- I see a straight yellow line of words across the bottom of the screen, with a blue line of words above it in a "rainbow" type of arch.
Does this sound like a mirror or projector/gun problem?
Also the upper left 1" corner of the screen is goofy too...
Here is a picture I just took... (sorry about the "flash")
I couldn't find anything at the panny site like your problem exactly except they say blue is the hardest to focus.
I see your pic is good except for the lettering, check that your cables are still properly connected to the in's and out's.
Edit: besides won't cost you anything.... :thumbs:
I remember when I hooked up my sub I rearranged some cables(spiders nest) and I mixed up two on the dvd to TV and I got something like yours, don't remember exactly what the pic was like except it was doubled somehow.
:cool:
John
John, actually there is blue ghosting (bow shaped) on the whole bottom of the screen. It's most obvious with the lettering, that's why I took the picture with letters on the screen.
A pic, that might help someone out quite a bit (but not me :cool: ).
Another link:
http://www.hometheaterspot.com/htsthreads/...hreads.php?Cat=
Sign up, basic membership is free. Try this site and post your question and pic in the toshiba forum. Lotsa good people over there that are willing to help. I strongly recommend you posting this problem over there. :thumbs:
I would avoid AVS forum as it has turned into a "bleeding edge" kinda site (only DLP's, LCD's or Plasmas need apply).
You might end up having to take the screen(s) off and look into the guns from above. Not a big deal, but ya gotta be extra special careful....
Hopefully Stebob will look in again and be able to give you some expert guidance.
Yeah...looks like gun and/or mirror got knocked out.
Have you tried different inputs on the TV? Composite, s-video, or component? If not, I would try that, too. I could be something related to that input or the cables feeding the signal. Unlikely, but worth checking out before you drop any cash. Honestely, if you don't know what you're doing, it's really easy to fubar your tv. I would go to a local specialty audio/video(high end) store and talk to them and see who they recommend.
Stebob, I checked my other inputs, and they are just as bad. I'm guessing it's a gun/mirror.
So far, I haven't had much luck getting anyone here to check it out... :cool:
That's what it sounds/looks like to me. Call some high end audio/video stores around you and see if they can help you find someone GOOD.
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,020 Guests (See full list)
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
