Receiver hitch failure
On some other forums I have seen evidence of the receiver on 00-03 Chevy's (to include a co-worker's 2500HD) suffering catastrophic failure while towing. Even if the tow is documented within the tow weight limits.
Has anyone on this forum suffered such a failure? I have just ordered a new Putnam Class-5 to replace my stock receiver hitch.
Is this a widespread failure or to small for a GM recall? Or does the majority of the population who own these trucks not really tow?
Cheers,
I remember reading someone else in here had that problem... it was quite awhile ago though. I can't really remember who it happened to, but I have a good guess... (I just don't want to mention the wrong person if I'm incorrect)
I towed around 6k lbs very frequently (2 to 3 times per week) on short, and long trips up until a few months ago. Zero problems out of either truck. Both have the factory installed class III hitch.
To answer your question directly, it's not a common problem.
I too remember one instance. I'm guessing it was nearly two years ago, and there were some pictures of a totally ripped receiver hitch. Impossible to imagine how that could have happened. I seem to recall that the post showed up on Edmonds, or maybe pickuptruck.com.
This kind of potential problem would NOT be on my list of things to worry about. GM certainly has a 2X safety factor for their hitches, and it may actually be closer to 4X. That would be a tow vehicle at the max rating, and pulled under stressful conditions as well (that is, high speed, bad road, etc.).
I'm sure the Putnam hitch folks -- and all the other companies that make after-market hitches -- would appreciate it if we all started tearing off our factory hitches and replacing them with something sexier. But may I suggest -- and please don't take this wrong -- that a better use for the money would be to donate it to the American Cancer Society, your local women's shelter, American Heart Association, food bank, etc. etc ????
gnutruk
I would also poo-poo this as internet hoopla if I had not seen this happen with my own eyes to my friend's 2001 2500HD. He was towing a 6000lb travel trailer using a weight distributing hitch. Turned a corner and the receiver was toast.
Yea, I've got plenty of money and time to replace stuff on my Tahoe that doesn't need to be replaced. NOT. I do believe in the utmost in safety however.
I was just curious if anyone else was having these problems.
BTW, go out and look at the GM hitch. Why does it have two bolts attaching the hitch to the bumper? The replacement hitch I am installing does not have those but it does have a 16,000 lb rating. Hmmm, I wonder? How does the bumper survive a 5mph impact without ripping those bolts out? Hmmm?
Just a thought not a flame.
Cheers,
WOW
Did he buy this truck new or was it used?
What exactly happened to the hitch?
He bought it new. The hitch separated at the single sided weld (problem) along the side of the receiver. Looked like a twisted pretzel.
Cheers, Doug
I'm towing about 9K with my 1500HD '02. no problems yet
but I'll keep doing inspections on a regular basis. BTW my
truck is rated to tow 10,000 lbs.
Am a GM fan, but not blindly so.
GM screwed up on the NBS receiver. Bone stupid design that is NOT strong enough.
Depends on transfering the WD hitch bar's loading to the bumper, then to the bumper brackets, then to the frame rails.
Reported and pictures at RV.net tow vehicles. Here's the link to the thread: RV.net thread on Suburban's receiver breaking
Here's some pictures from that thread and Burbman's picture album.
Link to his album if the above pictures don't make it:.....Burbman's receiver picture album
Cheers,
It has those two bolts on the bumper because they've cheapened the receiver. It no longer is strong enough by itself to do the weight distribution from the hitch to the frame rails.
Needs to transfer that force to the bumper. The bumper is designed to take a hit from different direction, so will bend in the direction the receiver pushes.
Then the bumper will try to transfer that loading to the brackets holding the bumper to the frame rails.
This "food chain" will bend the bumper and brackets so that not enough of the WD from the hitch is transfered. Why many can't drop their TV's front end wtih a WD hitch and WD bars...no matter how heave a bar and how many links tightened.
For those who still don't believe, take a 2 inch square bar about 6 feet long. Shove it into a NBS receiver and lift. Note that the receiver tube will bend towards the bumper, the bumper will move up and bend. It's brackets are behind so can't see them, but they will move before transfering enough load to the frame rails.
Also look at other NBS receivers that have been used to tow heavy. Most all I've seen in parking lots are bent either downwards or upwards.
A guy showed me where his hitch had ripped out from under his truck. He had replaced the rear bumper and didn't put the bolts back that attach the hitch to the bumper. He loaded a S-10 on his car hauler trailer and it bent the entire hitch assembly down and ripped the frame rails on the truck where the hitch was attached. Luckily he was not moving down the road when that happened.
Of course his leaving the bolts out was the cause of that, but that just shows what kind of leverage the design of the hitch gives the load.
I'd file a complaint with the NHTSA.
Like said before, am a GM person, but they've really done a stupide thing with thei penny wise, pound foolish receiver.
How many towing +10K lb trailer out there not knowing that they are close to losing it?
How many of us are next to that set up just about to lose their TT?
Here's the NHTSA complaint page to file: NTHSA complaint page
Thanks for that site Ben. Fortunately for me I have not experienced failure so I have no claim against GM. My mantra has always been "preventative maintenance before failure."
Cheers,
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 898 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
