New Gauge Cluster + Bezel
So I decided I wanted a new gauge cluster for my truck, But what to get? Well on March 12th I recived my order of a Hummer H2 White Faced Gauge Cluster....
Then on March 16th I recieved my order of a Platinum Escalade Bezel....
So I took the H2 Bezel off and replaced it with the Escalade one, and bingo....
You can see the new gauge cluster on the bottom with the hummer h2 bezel on top. What a difference some chrome makes, and I love the fact its around each one of the gauges and not just the tach and speedo.
Anyways I havent seen this combo on any other truck so I might be the first, :crazy: Which totaly rocks. I have to go up to Concord this week and get my milliage transfered over, going to cost me 30$ but well worth it. I will post some pics after I get it installed.
Got it all installed now, milliage transfered over. Everything is comming up milhouse.
12240395 $48.19 cents....plus shipping (rape) at gmpartsdirect.com
The best part about this setup all the parts are GM. From the white faced/red needle gauge cluster to the platinum escalade chrome bezel.
What color does the cluster light up at night??
I like what you have! :thumbs:
I also can not find the H2 cluster on GMpartsdirect.com either. Do you have a part number??
Thanks! :cheers:
the wiring for the tranny gauge is all there already..just plug-n-play on the cluster and everything works, if I remember right.
I would like to know where you got the H2 cluster from. I see the ones on Ebay say they will only work for the H2 and not the trucks. Is it a matter of changing the faceplate to make this work?
Thanks!
no temp trans gauge on my old cluster. This was a stock white faced h2 cluster that I just swaped the bezel on, had my milliage transfered over, and installed it. The h2 cluster is 2003 if that makes a difference. I will try to post some better pics of it tomorrow or sometime this week.
Sorry been busy xbox modding, thinking of putting an xbox in my truck. Got myself one of thouse halo limited edition green xbox's I am thinking of putting in.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   2 Members, 0 Anonymous, 503 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
