Can someone post or send me copies of the following GM Technical Service Bulletins?
Truck:
2003 GMC Envoy 4x4 6 cylinder
1. 03-08-42-006 JUN 03 Lighting - Tail Lamp Circuit Board Replacement
2. Fuel Sending Unit
Also, www.alldata.com only showed TSBs through the summer of 2003? Is there a better source of info for this?
Thanks :D
www.alldata.com is FREEEEEEEEEEEEEEEEEEEE
All you get for free at alldata is the TSB number, not the details :cheers:
For 03 trailblazer...should be same for envoy!
Office of Defects Investigation
Technical Service Bulletins - Search Results
Report Date : May 4, 2004 at 04:04 PM
TYPE : VEHICLE
YEAR : 2003
MAKE : CHEVROLET
MODEL : TRAILBLAZER
Make : CHEVROLET Model : TRAILBLAZER Year : 2003
Service Bulletin Num : 030235006 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10005165
Component: STEERING
Summary:
REVISED STEERING WHEEL REPLACEMENT PROCEDURE. *TT
Service Bulletin Num : 0810B Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005383
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM:FAN
Summary:
TICK NOISE AT IDLE. SIT BULLETIN 1409922. *TT
Service Bulletin Num : 00540B Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005417
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
ENGINE OIL LEAK AT INTAKE GASKET. SIT BULLETIN 1412496. *TT
Service Bulletin Num : 01579 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005422
Summary:
OIL PAN BAFFLES DELETED. SIT BULLETIN 1413402. *TT
Service Bulletin Num : 01577 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005437
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
Summary:
RADIO DISPLAYS CALIBRATION ERROR AFTER REPLACING RADIO. SIT BULLETIN 1413330. *MN
Service Bulletin Num : 01578 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005421
Summary:
COOLING FAN OPERATION. SIT BULLETIN 1413381. *TT
Service Bulletin Num : 01573 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005419
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:COOLING UNIT AND LINES
Summary:
RATTLE NOISE AND/OR TRANSMISSION FLUID LEAK FROM TRANSMISSION COOLER LINE CONTACT WITH CATALYTIC CONVERTER. SIT BULLETIN 1412499. *TT
Service Bulletin Num : 01592 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005438
Component: ELECTRICAL SYSTEM
Summary:
2003-2004 GENERATION 5 ONSTAR STEERING WHEEL CONTROL FUNCTION EXPLANATION. SIT BULLETIN 1416474. *TT
Service Bulletin Num : 00810A Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005468
Summary:
TICK NOISE AT IDLE. SIT BULLETIN 1404136. *TT
Service Bulletin Num : 01799 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10006327
Summary:
NO VOLUME FROM RADIO IN COLD AMBIENT TEMPERATURES FOR 20-30 MINUTES. ALSO INCLUDING MODELS 2003 BUICK RAINIER AND 2003 ENVOY XUV. *MR
Service Bulletin Num : 01663A Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10006296
Component: STRUCTURE
Summary:
VIBRATION NOISE FROM UNDER HOOD, SOUNDS LIKE SHEET METAL VIBRATING. SIT BULLETIN 1450413. *TT
Service Bulletin Num : 01764 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10006261
Component: FUEL SYSTEM, GASOLINE
Summary:
VEHICLE DIFFICULT TO FILL WITH FUEL/ FILLING STATION PUMP SHUTS OFF BEFORE TANK FULL. ALSO INCLUDING 2003 BUICK RAINIER. *MR
Service Bulletin Num : 01483 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005496
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
VEHICLE HAS NO PCM (POWER TRAIN CONTROL MODULE) COMMUNICATION WITH TECH 2. SIT BULLETIN 1400427. *TT
Service Bulletin Num : 00702A Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005476
Summary:
SLIP CONDITION IN 2ND, 3RD OR 4TH DAMAGED 2-4 BAND 3-4 CLUTCH. SIT BULLETIN 1402022. SIT BULLETIN 1402022. *TT
Service Bulletin Num : 00822B Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005474
Summary:
NO 2ND, NO 4TH AND NO REVERSE. SIT BULLETIN 1404714. *TT
Service Bulletin Num : 00969A Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005469
Summary:
ENGINE WHISTLE NOISE. SIT BULLETIN 1404163. *TT
Service Bulletin Num : 00682A Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005440
Summary:
PERCEIVED HIGH ENGINE RPM TRANSMISSION SLIP, DELAYED UPSHIFTS ON COLD START. SIT BULLETIN 1416476.
Service Bulletin Num : 020309002B Date of Bulletin: DEC 01, 2003
NHTSA Item Number: 10005147
Component: SUSPENSION
Summary:
INTERMITTENT BOOM, RUMBLING NOISE AND / OR DISTURBANCE HEARD IN PASSENGER COMPARTMENT WHILE DRIVING AT HIGHWAY SPEEDS. *TT
Service Bulletin Num : 030842014 Date of Bulletin: DEC 01, 2003
NHTSA Item Number: 10005185
Component: EXTERIOR LIGHTING:TURN SIGNAL:FLASHER UNIT
Summary:
NEW TURN SIGNAL FLASHER MODULE AVAILABILITY. *TT
Service Bulletin Num : 010730038A Date of Bulletin: DEC 01, 2003
NHTSA Item Number: 10005162
Summary:
SOME CSUSTOMRS MAY COMMENT THAT THE SERVICE ENGINE SOON LAMP IS ILLUMINATED, NO 3RD AND 4TH GEAR, THE TRANSMISSION DOES NOT SHIFT CORRECTLY, THE TRANSMISSION FEELS LIKE IT SHIFTS TO NEUTRAL OR A LOSS OF DRIVE OCCURS. *TT
Service Bulletin Num : 0308111002 Date of Bulletin: DEC 01, 2003
NHTSA Item Number: 10005189
Component: STRUCTURE:BODY
Summary:
PAINT CHIPPING BEHIND FRONT WHEELS/FRONT OF REAR WHEELS, DAMAGED LOWER DOOR/CLADDING AND ROCKER PANELS. *TT
Service Bulletin Num : 030863003 Date of Bulletin: DEC 01, 2003
NHTSA Item Number: 10005188
Summary:
RATTLE FROM FRONT OF VEHICLE. *TT
Service Bulletin Num : 00817A Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004124
Summary:
4.2L LL8 ENGINE STALL WHILE RUNNING EVAP DIAGNOSTICS. *TT
Service Bulletin Num : 01354 Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004136
Component: ELECTRICAL SYSTEM:BATTERY
Summary:
INTERMITTENT DEAD BATTERY. *TT
Service Bulletin Num : 00651B Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004201
Component: EXTERIOR LIGHTING:BRAKE LIGHTS
Summary:
REAR BRAKE LIGHT BULB OUT. *TT
Service Bulletin Num : 01410 Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004214
Summary:
POOR PERFORMANCE FROM A STOP IN 2WD, AUTO OR 4WD HI. 2003, 2003 CADILLAC EXT ALSO INCLUDED. *TT
Service Bulletin Num : 00827C Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004256
Summary:
SERVICE ENGINE SOON (SES) LIGHT ON WITH TAC MODULE CODES P1516 AND POSSIBLE CODES P1514, P1515, P1518. *TT
Service Bulletin Num : 01459 Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004261
Component: VISIBILITY:DEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING
Summary:
HVAC MODE ACTUATOR CAM GEAR ALIGNMENT IS INCORRECT AFTER REPLACEMENT. *TT
Service Bulletin Num : 01446A Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004255
Component: POWER TRAIN:TRANSFER CASE (4-WHEEL DRIVE)
Summary:
SERVICE 4WD LIGHT ON NO CODES BESIDES U1000 CODES. *TT
Service Bulletin Num : 00078E Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004246
Summary:
ENGINE KNOCK NOISE INITIAL STARTUP IN COLD AMBIENT 10 DEGREES CENTIGRADE/50 DEGREES FAHRENHEIT. *TT
Service Bulletin Num : 00817C Date of Bulletin: NOV 18, 2003
NHTSA Item Number: 10004241
Summary:
COLD IDLE STALL THAT OCCURS DURING OR IMMEDIATELY AFTER EVAP DIAGNOSTICS ARE RUN. *TT
Service Bulletin Num : 01314 Date of Bulletin: NOV 17, 2003
NHTSA Item Number: 10004094
Summary:
ENGINE MISFIRE POSSIBLE DIAGNOSTIC TROUBLE CODES (DTCS) P0300 - P0306. *TT
Service Bulletin Num : 030139013 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005552
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
REVISED MODE ACTUATOR REPLACEMENT PROCEDURE. *TT
Service Bulletin Num : 030604062 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005559
Summary:
THIS BULLETIN IS BEING ISSUED TO REVISE STEP 4 OF DIAGNOSTIC TROUBLE CODE (DTC) P2135. *TT
Service Bulletin Num : 030601028 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005558
Summary:
INFORMATION ON CORRECT PISTON USAGE. *TT
Service Bulletin Num : 030940006 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005592
Component: SEAT BELTS:FRONT:RETRACTOR
Summary:
INFORMATION ON AVOIDING FRONT SEAT BELT RETRACTOR JAMMING WHEN STORING SEAT BELT. *TT
Service Bulletin Num : 030730056 Date of Bulletin: NOV 01, 2003
NHTSA Item Number: 10005566
Summary:
4L60-E AUTOMATIC TRANSMISSION OIL PUMP FIRST AND SECOND DESIGN IDENTIFICATION. *TT
Service Bulletin Num : 100703 Date of Bulletin: OCT 07, 2003
NHTSA Item Number: 10004980
Summary:
INTERMITTENT HESITATION, STUMBLE OR IDLE STALL WITHIN MINUTES OF STARTING AFTER THE VEHICLE HAS BEEN SITTING FOR SEVERAL HOURS. GM VOICEMAIL LOG. *TT
Service Bulletin Num : 030604055 Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004317
Summary:
SERVICE ENGINE SOON/CHECK ENGINE LIGHT ILLUMINATED, MISFIRE OR ROUGHNESS, DIAGNOSTIC TROUBLE CODE (DTC) P0300 SET. *TT
Service Bulletin Num : 030857004 Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004735
Summary:
WET FRONT FLOOR CARPET. *TT
Service Bulletin Num : 030604060 Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004733
Summary:
INFORMATION ON NEW SPARK PLUGS AND GAPPING. VARIOUS MODELS INCLUDING PONTIAC GTO 2004. *TT
Service Bulletin Num : 030842006A Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004774
Component: EXTERIOR LIGHTING:TAIL LIGHTS:SWITCH
Summary:
TAIL LAMP CIRCUIT BOARD NOW AVAILABLE FOR SERVICE USE. *TT
Service Bulletin Num : 030604057 Date of Bulletin: OCT 01, 2003
NHTSA Item Number: 10004771
Summary:
INTERMITTENT HESITATION, STUMBLE OR IDLE STALL AFTER SOAK, HARSH 1-2 SHIFT, SLIPPING 1-2 SHIFT FOLLOWED BY A HARSH ENGAGEMENT. *TT
Service Bulletin Num : 092203 Date of Bulletin: SEP 22, 2003
NHTSA Item Number: 10005045
Summary:
TAIL LAMP CIRCUIT BOARD PART NUMBER INFORMATION. GM VOICEMAIL LOG. *TT
Service Bulletin Num : 030864032 Date of Bulletin: SEP 01, 2003
NHTSA Item Number: 10004342
Component: VISIBILITY:REARVIEW MIRRORS/DEVICES:EXTERIOR
Summary:
AVAILABILITY OF REPLACEMENT PARTS FOR OUTSIDE REARVIEW MIRROR. *TT
Service Bulletin Num : 030864033 Date of Bulletin: SEP 01, 2003
NHTSA Item Number: 10004343
Summary:
AVAILABILITY OF REPLACEMENT MIRROR ACTUATOR. *TT
Service Bulletin Num : 082103 Date of Bulletin: AUG 21, 2003
NHTSA Item Number: 10003825
Summary:
ACCESSORIES BRUSH GUARD PACKAGE ON VEHICLES WITH THE NORTH FACE EDITION. *TT
Service Bulletin Num : 081103 Date of Bulletin: AUG 11, 2003
NHTSA Item Number: 10003862
Component: CHILD SEAT
Summary:
THIS VME STATES THAT GM HAS DECIDED THAT CERTAIN VEHICLES DO NOT COMPLY WITH FEDERAL MOTOR VEHICLE SAFETY STANDARD 225 IN BOTH US AND CANADA BECAUSE THE OWNERS MANUAL DOES NOT INCLUDE THE LOCATION SYMBOLS FOR THE LOWER UNIVERSAL ANCHORAGE SYSTEM AND EXPLANATION OF THE MEANING OF THE SYMBOLS. RECALL 03039 FOR CHILD SEAT ANCHORAGE SYSTEM. *TT
Service Bulletin Num : 080503 Date of Bulletin: AUG 05, 2003
NHTSA Item Number: 10003871
Component: ELECTRICAL SYSTEM:IGNITION
Summary:
THE PURPOSE OF THIS MESSAGE IS TO PROVIDE INFORMATION ABOUT A NEW PRODUCT EMISSION RECALL. THE RECALL NUMBER OF 03042. THIS RECALL IS FOR VEHICLES IN DEALER INVENTORY ONLY. SOME OF THESE VEHICLES MAY HAVE BEEN BUILT WITH SPARKPLUGS THAT MISFIRE. *TT
Service Bulletin Num : 020421006B Date of Bulletin: AUG 01, 2003
NHTSA Item Number: 10004357
Summary:
INOPERATIVE 4WD/AWD LAMPS, INOPERATIVE 4WD/AWD SYSTEM. *TT
Service Bulletin Num : 020846010C Date of Bulletin: JUL 01, 2003
NHTSA Item Number: 10002998
Component: OTHER
Summary:
PROGRAMMING ONSTAR MODULE FOR CANADIAN FRENCH VOICE RECOGNITION. *TT
Service Bulletin Num : 062503 Date of Bulletin: JUN 25, 2003
NHTSA Item Number: 10003719
Component: VISIBILITY:WINDSHIELD WIPER/WASHER:LINKAGES
Summary:
WINDSHIELD WASHER NOZZLES BEING CLOGGED IR AIMED IMPROPERLY. VME MESSAGE. *TT
NHTSA Item Number: 10003721
Summary:
REAR LICENSE PLATE POCKET SEAL BEING ROLLED OVER DUE TO IMPROPER INSTALLATION. THIS A VME MESSAGE. *TT
Service Bulletin Num : 061903 Date of Bulletin: JUN 19, 2003
NHTSA Item Number: 10003710
Summary:
UNUSUAL VIBRATION FELT AT IDLE OR AT VERY LOW RPM DURING PARKING LOT MANEUVERS. ALSO RESIDENCE NOISE ACCOMPANYING THE VIBRATION. *TT
Service Bulletin Num : 061803 Date of Bulletin: JUN 18, 2003
NHTSA Item Number: 10003706
Component: VISIBILITY:POWER WINDOW DEVICES AND CONTROLS
Summary:
POWER WINDOW MOTORS OCCASIONALLY OR INTERMITTENTLY INOPERATIVE. DIAGNOSIS/TROUBLESHOOTING. *TT
Service Bulletin Num : 030139007 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002131
Summary:
AIR CONDITIONING (A/C) INOPERATIVE / INTERMITTENT, AIR CONDITIONER BLOWS WARM AIR. *TT
Service Bulletin Num : 030604030 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002166
Summary:
MULTIPLE DRIVEABILITY SYMPTOMS OF LONG OR HARD STARTS, CHUGGLE, ROUGH IDLE AND LIGHT OR INTERMITTENT MISFIRE DUE TO CLOGGED FUEL INJECTORS. VARIOUS MODELS INCLUDING 2000-2001 PONTIAC TRANSPORT. *TT
Service Bulletin Num : 010846002C Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002836
Summary:
PROGRAMMING OF REPLACEMENT ONSTAR VEHICLE COMMUNICATION AND INTERFACE MODULES (VCIM). *TT
Service Bulletin Num : 030604033 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002860
Summary:
REVISED DIAGNOSTIC TROUBLE CODE P0336. *TT
Service Bulletin Num : 030867004 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002878
Component: VISIBILITY:SUN ROOF ASSEMBLY
Summary:
PARTS AVAILABILITY FOR SUNROOF REPAIRS. *TT
Service Bulletin Num : 030866006 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002877
Component: STRUCTURE:BODY:HATCHBACK/LIFTGATE
Summary:
LIFT GATE GLASS HARD TO CLOSE. *TT
Service Bulletin Num : 030842006 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002867
Summary:
Service Bulletin Num : 030604031 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10002858
Summary:
REVISED DIAGNOSTIC TROUBLE CODE P1125. *TT
Service Bulletin Num : 030421005 Date of Bulletin: JUN 01, 2003
NHTSA Item Number: 10006121
Summary:
SERVICE 4WD LIGHT ON, 4WD INOPERATIVE, DIAGNOSTIC TROUBLE CODES C0300 AND/OR C0305 SET. *TT
Service Bulletin Num : 052303 Date of Bulletin: MAY 23, 2003
NHTSA Item Number: 10003671
Summary:
AIR CONDITIONER LOW PRESSURE CYCLING SWITCH INTERMITTENTLY INOPERATIVE OR STUCK OPEN/ INTERMITTENT AIR CONDITIONER OPERATION AND/OR LOSS OF COLD AIR. *TT
Service Bulletin Num : 052203 Date of Bulletin: MAY 22, 2003
NHTSA Item Number: 10003659
Summary:
PRODUCT FIELD ACTION 03012. VEHICLES ARE EQUIPPED WITH A MECHANICAL OVERRIDE THAT COULD ALLOW THE IGNITION KEY TO BE REMOVED WITH THE SHIFT LEVER IN A POSITION OTHER THAN PARK. IN ADDITION, THESE VEHICLES HAVE AN OVERRIDE THAT CAN ALLOW THE TRANSMISSION TO BE SHIFTED OUT OF PARK WITH THE IGNITION IN THE OFF POSITION. *TT
NHTSA Item Number: 10003661
Component: SERVICE BRAKES, HYDRAULIC
Summary:
PRODUCT SAFETY RECALL 03025. FRONT LEFT BRAKE PIPE MAY HAVE BEEN SCORED DURING MANUFACTURING. THE BRAKE PIPE MAY LOSE STRENGTH AT THE SCORE LOCATION DUE TO CORROSION AND FATIGUE RESULTING FROM BRAKE FLUID PRESSURE, VIBRATION AND TEMPERATURE CHANGES. *TT
Service Bulletin Num : 020139006A Date of Bulletin: MAY 01, 2003
NHTSA Item Number: 10002366
Summary:
DIAGNOSING POOR AIR CONDITIONER PERFORMANCE - AIR CONDITIONER STOPS BLOWING COLD, AIR CONDITIONER CYCLES ON AND OFF. *TT
Service Bulletin Num : 030842004 Date of Bulletin: MAY 01, 2003
NHTSA Item Number: 10002391
Component: EXTERIOR LIGHTING:HEADLIGHTS:HIGH/LOW BEAM DIMMER SWITCH
Summary:
HEADLAMP LOW BEAM BULB SOCKET NOW AVAILABLE FOR SERVICE USE. *TT
Service Bulletin Num : 031903 Date of Bulletin: MAR 19, 2003
NHTSA Item Number: 10001297
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
REAR AXLE PINION SEAL LEAK CONDITION. *TT
Service Bulletin Num : 031003 Date of Bulletin: MAR 10, 2003
NHTSA Item Number: 10001903
Summary:
THE LIFT GATE, OR LIFT GATE GLASS, BINDS WHEN OPENING OR DOES NOT OPEN COMPLETELY BECAUSE OF CENTER HIGH MOUNTED STOP LAMP OR CHIMSEL APPLIQUE HITS THE ROOF OF THE VEHICLE. *TT *JB
Service Bulletin Num : 030403 Date of Bulletin: MAR 04, 2003
NHTSA Item Number: 10001880
Component: AIR BAGS:FRONTAL
Summary:
DRIVER SIDE AIRBAG MAY NOT DEPLOY AS DESIGNED - PRODUCT SAFETY RECALL TO REPLACE DRIVER'S AIRBAG. *TT *JB
Service Bulletin Num : 030864006 Date of Bulletin: MAR 01, 2003
NHTSA Item Number: 10001264
Component: STRUCTURE:BODY:DOOR
Summary:
DOORS HARD TO CLOSE. *TT
Service Bulletin Num : 020235006A Date of Bulletin: MAR 01, 2003
NHTSA Item Number: 10001270
Component: STEERING
Summary:
SQUEAK, RUB / SCRUB TYPE NOISE IN STEERING COLUMN. *TT
Service Bulletin Num : 030846002 Date of Bulletin: MAR 01, 2003
NHTSA Item Number: 10001293
Summary:
DRIVER UNABLE TO CONFIGURE ONSTAR SYSTEM. VARIOUS MODELS INCLUDING THE 2003 ISUZU ASCENDER. *TT
Service Bulletin Num : 020421008A Date of Bulletin: FEB 01, 2003
NHTSA Item Number: 10001101
Summary:
SHUDDER, ROCKING MOTION, BINDING, FEELS LIKE VEHICLE IS TUCK IN 4WD WHEN TURNING AT LOW SPEEDS. *TT
Service Bulletin Num : 030417002 Date of Bulletin: FEB 01, 2003
NHTSA Item Number: 10001111
Summary:
WHINE NOISE FROM REAR AXLE. *TT
Service Bulletin Num : 020421002A Date of Bulletin: FEB 01, 2003
NHTSA Item Number: 10001144
Summary:
SERVICE 4WD INDICATOR ILLUMINATED, DIAGNOSTIC TROUBLE CODE (DTC) B2725 SET, TRANSFER CASE SELECTOR SWITCH IS IN ONE POSITION - INDICATOR LAMP INDICATES ANOTHER RANGE IS SELECTED. *TT
Service Bulletin Num : 030419002 Date of Bulletin: FEB 01, 2003
NHTSA Item Number: 10001123
Summary:
SQUEAK, SQUEAL OR WHISTLE NOISE FROM FRONT AXLE. *TT
Service Bulletin Num : 012103 Date of Bulletin: JAN 21, 2003
NHTSA Item Number: 10005095
Summary:
ENGINE OVERHEAT CONDITION WITH LITTLE OR NO HEATER OUTPUT. OASIS *TT
Service Bulletin Num : 011703 Date of Bulletin: JAN 17, 2003
NHTSA Item Number: 10005108
Summary:
FRONT BRAKE NOISE OR SQUEALING AFTER THE VEHICLES HAS SAT OVERNIGHT. GM VOICEMAIL EXPRESS. *TT
Service Bulletin Num : 030730001 Date of Bulletin: JAN 01, 2003
NHTSA Item Number: 10000943
Summary:
TRANSMISSION SLIPPING OR TORQUE CONVERTER CLUTCH (TCC) INOPERATIVE WITH NO SERVICE ENGINE SOON (SES) LIGHT DISPLAYED AND NO DIAGNOSTIC TROUBLE CODE (DTC) P1870. *TT
Service Bulletin Num : 121302 Date of Bulletin: DEC 13, 2002
NHTSA Item Number: 10002751
Summary:
ERROR MESSAGES WHEN PROGRAMMING A NEW MODULE. *TT
Service Bulletin Num : 120902 Date of Bulletin: DEC 09, 2002
NHTSA Item Number: 10002739
Summary:
BUZZ OR RATTLE NOISE COMING FROM THE FRONT END OF LIGHT ACCELREATION AT 25 TO 45 MILES PER HOUR OR OVER BUMPS. *TT
Service Bulletin Num : 020862004 Date of Bulletin: NOV 01, 2002
NHTSA Item Number: 10000463
Summary:
FRONT FASCIA WAVY. *TT
Service Bulletin Num : 020940005 Date of Bulletin: OCT 01, 2002
NHTSA Item Number: 10000157
Component: SEAT BELTS:REAR
Summary:
AVAILABILITY OF REAR SEAT SHOULDER BELT COMFORT GUIDES. *TT
Service Bulletin Num : 020864021 Date of Bulletin: OCT 01, 2002
NHTSA Item Number: 10000160
Summary:
OUTSIDE REARVIEW MIRRORS DO NOT RETURN TO THEIR ORIGINAL POSITION AFTER USING CURB VIEW ASSIST FEATURE. *TT
Service Bulletin Num : 020421008 Date of Bulletin: OCT 01, 2002
NHTSA Item Number: 10000174
Summary:
SHUDDER, ROCKING MOTION, BINDING, FEELS LIKE VEHICLE IS STUCK IN 4WD (CROW HOP) WHEN TURNING AT LOW SPEEDS. *TT
Service Bulletin Num : 020421006A Date of Bulletin: OCT 01, 2002
NHTSA Item Number: 10000173
Summary:
Service Bulletin Num : 020535006 Date of Bulletin: OCT 01, 2002
NHTSA Item Number: 10000175
Component: STEERING:COLUMN
Summary:
SQUEAK NOISE IN STEERING COLUMN. *TT
Service Bulletin Num : 020139006 Date of Bulletin: OCT 01, 2002
NHTSA Item Number: 10000178
Summary:
Service Bulletin Num : 020139005 Date of Bulletin: SEP 01, 2002
NHTSA Item Number: 10000058
Summary:
HVAC SYSTEM INOPERATIVE FOR A DRIVE CYCLE, POOR HVAC SYSTEM PERFORMANCE IN HIGH AMBIENT TEMPERATURES. *TT
Service Bulletin Num : 020309002A Date of Bulletin: SEP 01, 2002
NHTSA Item Number: 10000060
Summary:
Service Bulletin Num : 020844016 Date of Bulletin: SEP 01, 2002
NHTSA Item Number: 10000071
Summary:
WHINE, BUZZ, GENERATOR WHINE, WHINE TYPE NOISE HEARD ON ACCELERATION. *TT
Service Bulletin Num : 190702 Date of Bulletin: JUL 19, 2002
NHTSA Item Number: 637300
Component: OTHER
Summary:
CUSTOMERS MAY COMMENT THAT THE SERVICE FOUR-WHEEL DRIVE / ALL-WHELL DRIVE INDICATOR ILLUMINATED OR THE FOUR-WHEEL DRIVE / ALL-WHEEL DRIVE IS INOPERATIVE. *TT
Service Bulletin Num : 020421006 Date of Bulletin: JUL 01, 2002
NHTSA Item Number: 634893
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:COLUMN SHIFT
Summary:
SOME CUSTOMERS MAY COMMENT THAT THE 4WD/AWD INDICATOR LIGHTS ON THE SELECTOR SWITCH DO NOT WORK OR THE 4WD/AWD SYSTEM MAY BE INOPERATIVE. *TT
Service Bulletin Num : 020846008 Date of Bulletin: MAY 01, 2002
NHTSA Item Number: 634571
Component: OTHER
Summary:
INFORMATION REGARDING THE ON-STAR MODULE COVER RETAINING TAB BREAKING. *TT
