The purpose is to funnel cooler, cleaner air to the engine from outside the engine comparment. I believe it is design to reduce associated noise as well. If you remove it I recommend using an aftermarket kit in place of the stock air box. Otherwise the mass air sensor or intake tubing will not have any support and will just fall inside the engine comparment. I purchased an inexpensive kit ($40 vice $250 for other aftermarket setups) off eBay and it has worked fine for two years. I see several on eBay each time I browse. Check it out. :lol:
Whats the purpose of the stock air box? i was wondering what would happen if i took it off?
Noise reduction,but has a serious side affect of air restriction :lol:
I just ditched mine and put in a Pace Setter cold air intake from Summit racing :smash:
Its not as fancy as the K&N or Airaid or some of the others,but its a whole lot cheaper than them,easy to install,and does a fine job on my '95 TBI 5.7L,try lookin here
Pace Setter AirF/X
  • 3 weeks later...
CityDriver - did you notice a big difference with that air F/X system ? I've been considering an aftermarket air intake system also, but can't see spending up to $300 for something like that. $110.00 isn't too bad, though.
Thanks
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
