bbellowsZ71 Posted May 25, 2004 Posted May 25, 2004 hey how do u install marker lights......i'm guessing you have to drill holes in the roof of your truck.and that doens't sound to good\? but i'm just wondering i've been thinking about getting them but arnt sure how they install thanks!
Putz Posted May 25, 2004 Posted May 25, 2004 I would also like to know how to do this. Can I assume that the wiring harness is already installed and that you just have to drill some holes to mount the lights? Does anyone know a good outlet for buying the cab lights? Thanks.
2001 HD Posted May 26, 2004 Posted May 26, 2004 Most likely the wiring is not in place unless it was an available foctory option for your year. The only one I know of is the 2500HD. You will have to drill holes in the roof and run wiring under roof liner and down windsheild pillar. I would seal the mounting/wiring holes real good as they have a tendency to leak. The only source that comes to mind is JC Whitney.
KENWORTH-1 Posted May 27, 2004 Posted May 27, 2004 I installed the Roof Lights..how I got the spacing of the lights.. by going to a Dealership on a Sunday with a tape meaure. Go to any Truck on the Lot that has the lights on them and take carefully measurements. It worked great for me! Here are the Part Numbers: Roof Lamp Center #15059751 Side Lamps (2) Required # 15059752 Harness # 15366160 I also installed the LED Light Stripe under the tailgate of my truck that fits onto Dually. But, I made it fit on my Truck with minor modifications Part # LED Light Stripe # 15744722
