Grinding brakes?
Whenever I shift out of park and begin to move I can hear a horrible grinding coming from the rear brakes. It doesn't occur when driving at any decent speed, but from a standstill or at speeds less than 2 mph it gets bad, especially the lighter I press the pedal. It's not a high pitched squeal associated with worn or really new pads, just a grinding sound that is absurd. The vette doesn't grind, and the old truck never had this problem. Suggestions before I go to the dealer :seeya:
How many miles??? Have you done any offroading recently??? Its possible that you may have caught a pebble in between the pad and the rotor surface. I'd take it to the dealer.
Never heard any grinding sounds from my rear brakes, but within 9 months of owning the truck it was at the dealers because the pads had cut grooves into the rotors. They were able to resurface the rotors and the problem has not re-occurred since.
For your truck, especially cuz it's brand-spanking new, take it to the dealer. Based on how that goes and what happens, make sure you express how you feel to GMC's customer care when they called. I can almost guarantee they'll never call me again after the last time they spoke with me.
There is a TSB from GM on the same complaint I'll try and find the post on it.
Here you go;
Bulletin No.: 02-05-26-002A
Date: February, 2003
TECHNICAL
Subject:
Scraping Noise From Rear Of Vehicle
(Replace Parking Brake Shoe Kit and Clean Drum In Hat Rotor)
Models:
2002-2003 Cadillac Escalade, Escalade EXT
1999-2003 Chevrolet Silverado 1500 Series Pickups
2000-2003 Chevrolet Suburban, Tahoe 1500 Series Models
2002-2003 Chevrolet Avalanche 1500 Series Models
1999-2003 GMC Sierra 1500 Series Pickups
2000-2003 GMC Yukon, Yukon XL 1500 Series Models
This bulletin is being revised to add Suburban and Yukon XL models. Please discard Corporate Bulletin Number 02-05-26-002 (Section 05 - Brakes).
Condition
Some customers may comment on a scraping noise from the rear of the vehicle while driving. The noise may be intermittent.
Cause
Condition may due to the parking brake shoe contacting the drum in hat rotor without the parking brake being applied, causing premature wear on the shoe lining.
Correction
Replace the parking brake shoe and install a new designed spring clip retainer. Follow the service procedure below to correct this condition.
Hope this helps.
    BakNBlk
    BakNBlk
  • Who's Online   2 Members, 0 Anonymous, 618 Guests (See full list)
