Cheap way to recalibrate for tire size?
Hey all,
In another post I read that going to larger tires will give you a inaccurate reading on your mileage. I just bought a '01 Sub with a 8.1L that has 325/60/r18 on it (no lift) and my calculated gas mileage is lower than what a lot of guys are posting while towing a house and I don't tow anything. On the first tank it was sub 10 MPG. I know what I was getting into when I bought the 8.1L, so I'm not losing sleep about the gas mileage, but I hoping that maybe it's doing better than I figured.
Besides buying a programmer, is there a cheap way of calibrating for the larger tires?
Thanks.
John
You might talk a dealer into it. Also if your axle ratio is a bit tall, the larger tires can lug engine a bit in OD and further hurt MPG. With the pre votec truck you could change a 5 buck gear in tail shaft to fix speedo calibration.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
