some interior pics
i finally finished painting some of my interior pieces and under the hood. i took out all my blue wire loom and going to switch to white. whatcha think?
Nice truck.
What gauges are you running in you Pillar Pod?
im running an a/f gauge, nitrous preasure, and trans temp(which i still have to install)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
