Transmission Bang
I have 1994 1500 4x4 with a 5.7 and 134,000 miles. The shift from first to second it very hard. Hard enough to jerk you in your seat. The rest of the gears shift fine and it runs great just the first shif is very hard. I bought the truck like this. I was told that it was a vac. like problem but havent had a chance to examine it yet. The fluid looks good and is not leaking any where. Let me know what you think may be the cause of this. THANKS.
