check engine light P0430
Is my catalytic conveter already bad?! My truck has only 76K miles.
I have a 1997 K1500 z71. It's all stock except for flowmaster dual exhaust.
The code P0430 I believe is a "Catalyst deterioration" code. And if that is the correct definition of the code, you will need a new Cat converter installed. Cat converters are covered by Federal Emissions warranty for defects for 8 years and or 80,000 miles. Whichever comes first.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
