Need help with third brake light install
I have a third brake light on my trucks cap that I want to use (I hook it up to my trailer harness).
It works but when I use my turn signal on one side it flashes.
When I use the adjacent wire (on trailer harness), the other turn signal makes it flash.
Is there a way I can hook it up to remain on when applying brakes and using both turn signals?
btw it's a 1991 c1500
t
Welcome to the Forum :seeya:
This may sound like a pain,but you could run a wire right to the brake light switch..
Or you could run a wire to each tailight..BUT you will have to ISOLATE them with a diode on EACH wire so that the turn signals will work properly.
You should also look at the wires under your truck. On my 1998 there is a wire just for that purpose in the plastic sheathing where the tail lights plug in to the wires on the frame. I don't remember the color but it was marked for that purpose.
    JustusTX
    JustusTX
  • Who's Online   5 Members, 0 Anonymous, 661 Guests (See full list)
