ok this is my first time on this site and i am getting ready to buy my first gmc sierra. I'm so excited and can't wait to get it.
Does anyone know if you can take a dash from a 2002 sierra denali and install it into a 2001 gmc sierra? Next is there a plug in for the info center in a regular extended cab sierra? And last but not least is there a transmission temp in sierra's?
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 257 Guests (See full list)
