mine
Looks awesome. Like the wheels, tires, door handles, and lift. My only suggestion is to find a way to re-fabricate the nerf bar mounting brackets to raise the nerf bars and account for the body lift. That's the problem with nerf bars and body lifts -- it leaves too much evidence of how the truck was lifted.
d**n Thats alot of whiteness, how come you didnt paint the lower valance under your bumper white? I mean you got everything else, you should have went the distance. :banghead:
Thanks for the great suggestions! I actually like where the nerf's are right now...they are perfect stepping height. As for painting the bumper....I've always associated that with 1 step to far. I guess that's why harldy anyone's ride looks the same!
great pics. that's about how i am hoping my 99 silverado will look. what size tires?
Truckman: My trucks an LS and has full prw seats. Guess I always thought that was the standard. Not sure though..
ok nevermind, I went back and look at the pic again. Not FULL pwr afterall. The only thing that's not is that ball that turns so your seat can dig into your back (whatever that thing's called) never been a big fan of that myself. just to clear up though..
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
