Braking improvement???
OK, just purchased a used 1997 Tahoe, 4dr 2wd. The brakes lack any real stopping power. I am not experiencing any brake fade or pull. Just a general feel that the brakes suck. Takes more pedal preesure than my 01 Sierra. Is there anything I can do? I've heard about cross drilled rotors, stainless steel brake lines, and converting the rear drums to rotors. Has anyone else done this? Are the cross drilled rotors worth it? My wife doesn't like driving it because she feels like she's going to rear end someone.
I've read alot in these forums about the lack of stopping power in the older Tahoes. Personally not a fan of cross-drilled rotors...cracking issues. I have a set of cryogenically treated slotted rotors and pads on my 99 NBS truck, got them from Praise Dyno Brake...and man this thing stops on a dime! I'm pretty sure they make a set for your truck too. The website is www.praisedynobrake.com. Small joint located in Texas, takes orders over the phone, answers all of your questions, and ships you what you need. Of course if you have some bucks to spend, converting to rear disc is always nice too.
i've got slotted rotors and stainless lines and it made a world of a difference. haven't done the rear conversion yet (mainly because of the price tag), but would like to.
the cross-drilled rotors are like asking green or red antifreeze. i was told by a supplier that the cross-drilled had a tendency to crack on a daily driver. but i've talked to people that are running them on street vehicles and haven't had a problem out of them.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
