What Part of the Drivetrain Moves
I hope this doesn't come across as a dumb question, but I have the autotrac transfer case and was wondering when my truck is in 2WD (about 98% of the time), what parts are actually moving? Does the transfer case have moving parts? The front differential?
The reason I ask is that I am about to change all my fluids (transmission, differentials, transfer case, oil, etc). and am wondering if changing the transfer case fluid is necessary. I am going to guess that some parts do move in there and that I should change the fluid, but I just wanted to make sure.
Thanks! :banghead:
I am pretty sure that it is switched at the front differential so the front drive shaft is spining all the time
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
