Keyless Remote Works
I am out of warranty. I thought that the battery in the keyless remote died. I was wrong (see honey....I CAN say it) .
It is clear that the receiver in the truck is not picking up the signal. Anybody know what it is I need to replace and/or where I can get it?
  • 2 months later...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
