taillights
if you have the newer chevy and looking to switch to these...I have two complete taillights, no scratches or cracks. complete bulbs and wiring harnesses...so all you have two do is plug them in. make me an offer if you're interested.
I'm confused, do you have Chevy or GMC lights? I'm looking for some 2003 or 2004 Chevy lights to go on my 2004 GMC. I like the new Chevy lights...
does anyone know if these will fit my 01 chevy 2500hd ? if so im very interested.any pics of them ?
thanks
Yes, they will.
Do you have the taillights now with the black trim on them? If so, and they are in good shape, are you looking to get rid of them?
I'm located in southern California. and I'm pretty sure they'll fit on the 2500 chevy. shipping shouldn't be too much on these, if you're not local.
