big ol' tires
does anyone know of a site that will show you compared pictures of 265s, 285s, and 305s? I know there saw something with a jeep wrangler that showed what it would look like with a 1", 2", 3", 4", 5", or 6" lift. And then you could select three different tire sizes with it, and it would show you what it looked like. Does anyone have a pic of stock Z71 with 305s?
I don't know if 305's will fit. I have a 93 Z71 and with 285?75/16's(33's) my tires will rub if I turn all the way, or really flex the suspension. If you get a set of long add a leafs, and crank up your torsion bars you might get away with it, but expect to either adjust your inner fender wells and wheel openings with a B.F.H. oryour tire will do it for you.
I have an 02 Z71 with 305's on it, they fit fine with no rubbing....granted I do have the torsion bars raised and the back end is lowered with the 2" drop shackles.
did you have to do any trimming for the 305s even with the tbars cranked? what do yall think about add-a-leafs?
how do shackles work?
Shackels make the truck go down, not up. Who would want to do that to a 4x4 :lol:
They actaully are longer than the stock shackles making the truck hang off the spring lower.
No, I didn't have to trim anything. Tires fit perfect, several of my buddies are running this tire with no problems..
QUOTE (txpkup @ Jul 15 2004, 11:52 AM)
I like the shackles because it completely gets rid of the "stink bug" look the trucks come with...and now the truck has a raked look to it, very cool IMO :lol:
One question... How can you have a raked look if the Tbars are cranked up and you put drop shackles in the rear?
--Mike :lol:
so this reverse-rake makes you look like you're haulin a load and draggin azz when you ain't?? poser truck!!!!!
poser truck??? :cool:
Its actually sits very close to level!! ... You have no idea what this looks like and you criticize my truck!
Its raked front to back, unlike where the nose is lower than the rear....
I have a picture that I can email you, but I have no way of hosting it on the web...
I'd like to see it. Email it to me, and I'll host/post it here for you. :cool:
[email protected]
