Chevy/GMC Stuff
I still have the following for sale:
Bushwacker bed rail caps. Black ribbed, fits 99+ Silverado/Sierra SHORTBED LD/HD $55 + shipping. They are Brand new unopened in the box.
Keyless remote transmitters (GM OEM) for S-series pickup trucks. I had these for my 00 ZR2 as spares. Mint condition. $25 for both shipped to your door in the US.
Brand new radiator for ZR2 S-10. Was for my 00 ZR2 before I sold it. Never installed, never opened. $150 + shipping. Made by GDI, has lifetime warranty.
Brand new A/C Compressor. Never installed, never used. No way in hell you'll find it this cheap.
$200+shipping.
Has gm warranty, etc.
AC Delco Part # 15-20145
GM# 1136521
Fits a TON of motors gm v6 & V8 motors.
www.acdelco.com and search the part #
Slowly I'm selling it, but it has to go.....make fair offers if you feel the need..
  • 5 weeks later...
$200+shipping.
GM# 1136521
Make me offers on everything. IT has to go. Be fair and we'll work something out.
This stuff is getting in the way!
Hmmmm....I may need a compressor for my 92...It's making a bit of noise....Any chance you know if it will fit?
'92 350 TBI.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
