285-75r16 help
OKAY ALREADY ASKED THIS QUESTION BUT NOT ANSWERED
TO WELL IM PURCHACING A 2004 GMC 2500HD CREW CAB 4X4
DURAMAX/ALLISON MY QUESTION IS WILL THE 285S FIT WHAT
WILL I HAVE TO CHANGE RAISE TORSION BARS WHAT WILL IT
RUB OR IS IT JUST TO MUCH TIRE FOR THIS I DO PLAN I TOWING
A TRAILER ANYONE OUT THERE PLEASE GIVE ME YOUR THOUGHTS
DOES IT EFFECT GAS MILAGE :cool:
you will probably have to crank the torsion bars up a bit and thereare some "inner fender" spots that will need to be zip tied a bit but thats all. Only time mine used to rub was when turning and backing up at the same time
I had 285's on my Sierra 2500 and only had to trim the inner splash shield a little bit. I think I raised the front about 1" with the torsion bars. I now have 305/70/16's on 9" wide wheels on it now and when I first installed them they would rub on the rear part of the slpash shield when backing up. I removed the plastic push rivets and replace them with zip ties and do not have the problem now, even with the 305's.
I had my truck leveled by having the torsion bars turned up. Do not let them crank them all the way as the ride will be crap. Mine is level now and I run 305/70/16's and never had to zip tie anything or trim anything. They fit perfect on the stock aluminum wheels..
I can send you some photos if need be.
Id like to see pics of the truck with the 305s. I currently have 285s, and was considering 305s but I was thinking they would be too large w/o a lift. Thanks in advance.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
