Allison Trans Shifting
2500HD Diesel, Allison. Between 2nd & 3rd gears, the engine rpm drops about 200 rpm, almost as if it is shifting. More noticable towing heavy loads. Does anyone else have this symptom??
Are you using the tow haul button? My Allison did something like that when I first got it and has not done it since. I have chipped it so the trans had to go through a learning mode again...
The Allison has torque convertor lock-up through the top 3 gears (or is it even top 4?). Sounds like TC lock-up is what you are experiencing. Lock-up will vary depending upon tow/haul, speed and other conditions.
YES, I am using tow-haul mode when towing a trailer. However, this happens when in tow-haul or not, towing a trailer or not. It is just more noticable when towing a heavy load.
