A/C Idler Pully
Does anyone know the part number for the a/c idler pully?   since it has turned cold down here in the south, mine has started squeeking till it warms up.  verry annoying.  :D
Matt G.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
