2005 BMW M5
5.3LSilverado01
* New 90-degree V-10 with 507 horsepower and 383 lb-ft of torque (European measure)
* Redline: 8250 rpm
* One hundred horsepower per liter of displacement
* Double-VANOS variable valve timing
* Electronically controlled throttle butterfly for each cylinder
* MS S65 engine management system features most powerful processors currently approved for use in automobiles
* Seven-speed SMG transmission with steering wheel shift controls
* Twenty percent faster shifts compared with last-generation SMG
* Drivelogic with eleven program options that enable shift characteristics to be tailored to suit the driving situation and the mood—six of these programs can be selected in the sequential manual gearbox mode (S mode)
More
I'm sure it's a great car and an M5 is one of my dream cars, but I think I would prefer one of the ones that are a few years old. I haven't heard very good reviews of the confusing "I-Drive" system, and I think the new M5's have a version similar to the ones in the new 7 series. (Correct me if I'm wrong)
actually, the word is that the New 5's version is only HALF as messed up as the 7 series version. :cool:
LOL, still sounds sad
You would almost certainly need to take European Delivery on this one. I would want to drive it on the roads it was designed to drive on before bringing it back to the US where it will be crippled. You can even sell it to the wife as a "family sedan" :jester::cheers::eek: Hey Honey.....it has 4 doors. It looks nice. I loved my 1999 M3, but it was just a little bit too small. This would be perfect. Thanks for the news.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,133 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
