FS: Powermaster alternator
200 amp powermaster alternator for NBS gm trucks. fits 4.8 5.3 6.0's
Paid $395 from summit racing and only had installed for a few months.
$200 shipped or best offer
Can you give a little more info? Does this require a different belt than stock? Does this cause any radio interference? Why are you selling it? Thanks.
sure... stock belt is fine and takes about 10 start to finish to install. My motor revs too high for this alternator and I am still in the process of making a dual alt set up
oh yeah... i didnt have any interference or speaker whine with it. Only thing i did notice is a bit of noise from the pulley itself. Some people even asked what kind of blower I had :cool:
