K2500 bumper
the bumper on my 99 silverado 1500 is damaged. hit and run, no luck with lisence plates.
But I was wondering on what the cheapest way to buy a new one would be. There's a 2002 K2500 on ebay right now. Are the 02 3/4 ton bumpers the same as the 99 1/2 tons?
I believe that you need to swap out the grill to get it to match up correctly.
I'm not 100% sure on that but I think I've seen that talked about on the forums before.
  • 4 weeks later...
Since you are in Texas, go to a Ranch Hand dealer and see if you can have a used bumbper that has been taken off a similar Chevy.
I just replaced my front and rear bumpers with Ranch Hand bumpers and the place had three racks of used bumpers that they were going to send to scrap. They told me that the return is only enough to cover the gas to get the old bumpers to the scrap yard. And this was in Colorado. I'm sure Texas has lots of Ranch Hand dealers. I was going to try and sell mine on eBay, but decided against it when I saw all of the old ones at the shop.
Cheers, Doug
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
