FS: Black 03' Silverado 1500 LS Reg. Cab
2003 Chevrolet C1500 Silverado Regular Cab, Short Bed, LS, 25,000 miles
4.8L/Auto, 3.42 rear-end
LS Trim (Compass/Temp Mirror, All power, exterior trim, factory tint, etc)
Maintenance followed strictly... Synthetic Tranny Fluid, Oil, and Rear Diff.
OEM Transmission cooler, Hidden Hitch, and "Hoppy" 4/7 combo hookup
It's pulled no more than 2,000lbs, and only been used to tow that 4 times.
Additions:
-Wester's Custom 89 Octane Tune, 22/23 MPG Highway Mileage, Shift Points raised, firmer shifting, raised speed limiter to 130MPH.
-Line-X over the rail bed liner w/lifetime warranty
-K&N FIPKII, with K&N Drycharger & Recharge Kit
-Custom Magnaflow Stainless muffler w/dual exhaust 3"in X 2(2.5")out, and stainless 3" tips exiting out the back
-Kenwood CD head unit, Kenwood 6.5" fronts, 4X6" Polk Audio rears, Bazooka Amplified 8" subwoofer model EL8
-Wade Bugshield
-AutoVentshade In-channel vent visors.
(All Factory Parts other than the original PCM included, PCM can be returned to stock if need be... Factory Air intake, OEM muffler, cd head unit)
I'm located in Jackson, MS and don't really have a way to ship it. I'm changing jobs and have to really cut back on everything, so I have to start here... The truck is in like new condition with the exception of two rock pecks in the windshield (they've been professionally repaired, no running) and a very small paint rub about 1/4" in length where someone opened their door into the truck, no damage just a little paint speck that I'll probably buff out tonight.
I'll take some pictures tonight or tomorrow night, and will be happy to send them through email if you're interested. You can contact me via email at [email protected] (Just remove the NOSPAM part) if you have any questions, I'll email you some pics and more contact information then as well.
I'm asking $18,500. Thanks!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
